  2. Functional Verification
  3. UVM_ML (SystemC + SystemVerilog TB)
  • Subscribers 67
  • Views 17019
vitok
vitok over 11 years ago
Question about architecture of SystemC UVM  + SystemVerilog UVM.
Can those two approaches be mixed?
1. Can SystemC uvm_components exist within SystemVerilog's UVM tree hierarchy?
  In other words - can SystemVerilog instantiate SystemC class in itself?
2. If SystemVerilog UVM cannot instantiate in itself UVM components of SYstemC - it will mean that the testbench will have multiple tops (one top for SC, the other for SV), is it correct?
Many thanks
Witold Kaczurba
  • hannes
    hannes over 11 years ago
    Hi Witold,
    My answers are with respect to the latest multi-language solution, UVM ML-OA, which is available here:
    http://forums.accellera.org/files/file/65-uvm-ml-open-architecture
    U
    sing the above package (which also has detailed documentation), the answer to your question 1 is yes, you can create
    a mixed language hierarchy. However, you cna also have multiple tops (question 2) if this is what you prefer.
    -hannes
  • vitok
    Hi hannes
    Perfect. I saw the example here:
    in UVM_ML-1.4.4/ml/examples/unified_hierarchy/sc_sv
    I did not get a chance to run it yet as I encountered some issues with installation of the package (hopefully solvable soon.)
    Thanks for your email.
    Rgds,
    Witold
  • vitok
    All working thanks.
