  2. Functional Verification
  3. Redirect Spectre results to buffer
  • Subscribers 67
  • Views 15449
Khenglish
Khenglish over 11 years ago
I have written a program which reads in a text formatted tran.tran Spectre results file, analyzes the results, then modifies component parameters within input.scs in attempt to improve circuit behaviour. it does this repeatedly for many iterations.
The problem I am having is that the tran.tran file can be very large, making it time consuming to write and read a result file on the disk. I would like to know if it is possible to redirect Spectre's output to a memory buffer which my program could read from, avoiding the overhead of hard disk IO.
  • Khenglish
    I ended up working around this issue by stopping spectre from saving every node in the tran.tran file at every timestep.
    in input.scs:
    saveOptions options save=selected
    Now the simulation literally runs twice as fast.
  • Khenglish
    Khenglish over 10 years ago
    Writing and reading the tran.tran file is leading to some issues with the Linux file system. I would still like to be able to write to a buffer than can be read by an external program to circumvent the file system. Is that possible?
