  2. Functional Verification
  3. How to use cve_coverage_save_nc?
  • Subscribers 67
  • Views 15666
ciroceissler
ciroceissler over 11 years ago
I'm trying to do functional verification using SystemC.
I already create an structure using scv_coverpoint and scv_covergroup, and I can extract the coverage from covergroup using the function coverage() from scv_coverobject_if base class.
The problem is when I try to generate the results to visualize with iccr gui.
Example of code:
int count;
ncsc_viewable<int> vcount;
scv_covergroup cgp_count;
scv_coverpoint cov_count;
cve_coverage_save_nc();
cov_count.cover(scv_expression::create_reference(vcount),
                scv_coverbin::DYNAMIC);
cov_count.sample_at(&this->vcount);
cgp_count.cover(cov_count);
I execute with 'irun -coverage all' and I get this message error:
ncsim: *E,SIGUSR: Unix Signal SIGSEGV raised from user application code.
When I remove the function cve_coverage_save_nc, works without problem but I can't visualize with iccr.
Any idea? What I am doing wrong? Exist an example of how to use this function?
Best Regards,
Ciro Ceissler
  • StephenH
    StephenH over 11 years ago
    Hi Ciro.
    I'm not completely familiar with the CVE coverage, most folks use Specman/e or SystemVerilog now because these are more expressive languages for coverage. I suspect the problem is that you are calling the cve_coverage_save_nc() function too early, before you have completely set up your coverage points. The examples I have all follow the recommendation of using the constructor macros, so it's possible that you have omitted something vital that the macros would normally provide.
    If you ping me your corporate email address to stephenh _at_ cadence.com I can send you a fully working example that you can crib from.
    Another thing to note is that iccr is an obsolete technology, please consider using the newer "imc" analysis tool which replaced iccr a few years ago; it's a much nicer tool and more powerful.
    Steve.
