  2. Functional Verification
  3. HAL lint check design_info file
  • Subscribers 67
  • Views 18551
zeoshin
zeoshin over 11 years ago
Hi, I am trying to turn off some checking rules in the design_info file. I tried the example given by reference manual
INFNOT {pattern = "*unused_*"} off;
and it does not work. I also tried
INFNOT {pattern = *unused_*} off;
but it seems that it exempts the whole file from INFNOT rule instead of lines containing that pattern.
Anyone has an idea what's the correct way to exempt rule checking based on pattern?
  • StephenH
    StephenH over 11 years ago
    Did you remember to pass the design_info file to irun?
    It works fine for me if I do "irun -hal hal_play.sv -design_info design_info", where design_info contains:
    lint_checking file = *
      INFNOT {pattern="*unused_*"} off;
    And where hal_play.sv contains:
    module hal_play(input clk, input d, output bit q);
    wire unused_ok = 1'b1;
    wire bad_bad = 1'b1;
    always @(posedge clk) q <= d;
    endmodule
    I see only one INFNOT message:
    grep INFNOT irun.log
    halstruct: *N,INFNOT (./hal_play.sv,16|0): Ignoring wire 'bad_bad' with no fanout to module/design-unit outputs or child instances.
