  2. Functional Verification
  3. [HELP] Error on cosimulation of VHDL and SystemC with e...
  • Subscribers 67
  • Views 17308
[HELP] Error on cosimulation of VHDL and SystemC with e testbench
Vinicius Alves
Vinicius Alves over 11 years ago
I'm currently working in a project that I need to cosimulate two identical RTL DUTs in different HDLs (SystemC and VHDL) with a e testbench based on UVM. To do this I use irun to call necessary tools to compile and elaborate the DUTs and testbench and the call the simulator, I'm currently using Specman on master mode and ncsc to simulate the SysC DUT.
This is the way I'm invoking irun:
#! /bin/sh
SPECMAN_HOME=`sn_root -home`
# env-s
test_name_vhd="top.vhd utmc.vhd reset_sync.vhd"
test_name_vhd_ent=top
test_name_sc="reset_sync_main.cpp "
test_name_sc_mod=reset_sync_top
top_e_module=utmc_reset_sync_sc_config
##test_name_vhd=xor
# Prepare a working directory
mkdir ncsc$$
cp `dirname $0`/* ncsc$$ 1>/dev/null 2>&1;
cd ncsc$$
# invoke irun
irun  "$@" \
    $test_name_sc \
    $test_name_vhd \
    -snload ${top_e_module}.e \
    -sysc \
    -DSN_USE_DYNAMIC_C_INTERFACE \
    -I. -I${SPECMAN_HOME} \
    -top ${test_name_sc_mod} \
    -top ${test_name_vhd_ent} \
    -smartorder \
    -v93 \
    -scsynceverydelta on \
    -gui
cd ..
# Clean up
rm -rf ncsc$$
#-scsynceverydelta on
    #-sysc \
    #-DSN_USE_DYNAMIC_C_INTERFACE \
    #${test_name}.cpp \
Though I succeeded the cosimulation of a simple model (an XOR), when I moved to the actual DUTs I need to verify I get an error on a file that's automatically generated by irun (runvstub.cpp):
ncsc: compiling $TESTDIR/reset_sync_main.cpp
ncsc: compiling $TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp
make: *** [INCA_libs/irun.lnx8664.13.20.nc/ncsc_run/ncsc_obj/runvstub.o] Error 1
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 143: error:
          identifier "top" is undefined
      return snsc_convert_to_int32(top.asyncrst_n_i.read());
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 147: error:
      top.asyncrst_n_i.write(int_to_T_with_bp(top.asyncrst_n_i.read(),val,bit_preserve) );
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 149: error:
      top.asyncrst_n_i.write(uint_to_T(top.asyncrst_n_i.read(),val) );
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 153: error:
       put_T_to_mvl_list(3,top.asyncrst_n_i.read(),value,1);
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 156: error:
     top.asyncrst_n_i.write(mvl_list_to_T(3,top.asyncrst_n_i.read(),l,bp,1));
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 159: error:
     top.asyncrst_n_i.write(mvl_to_T(3,top.asyncrst_n_i.read(),mval));
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 191: error:
          class "sc_core::sc_in<sc_dt::sc_logic>" has no member "write"
      specman_p->ptr_0->asyncrst_n_i.write(int_to_T_with_bp(specman_p->ptr_0->asyncrst_n_i.read(),val,bit_preserve) );
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 193: error:
      specman_p->ptr_0->asyncrst_n_i.write(uint_to_T(specman_p->ptr_0->asyncrst_n_i.read(),val) );
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 200: error:
     specman_p->ptr_0->asyncrst_n_i.write(mvl_list_to_T(10,specman_p->ptr_0->asyncrst_n_i.read(),l,bp,1));
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 203: error:
     specman_p->ptr_0->asyncrst_n_i.write(mvl_to_T(10,specman_p->ptr_0->asyncrst_n_i.read(),mval));
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 227: error:
      sensitive  << sensitive_neg_wrapper(top.clk_i);
          no instance of overloaded function "sensitive_neg_wrapper" matches
          the argument list
            argument types are: (<error-type>)
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 234: error:
          no instance of overloaded function "sensitive_pos_wrapper" matches
          the argument list
      sensitive  << sensitive_pos_wrapper(top.clk_i);
"$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp", line 241: error:
          the argument list
ncsc: Error executing: $CDSROOT/tools/cdsgcc/gcc/4.4/bin/g++ -DNCSC -DCADENCE  -DLNX86 -I$CDSROOT/tools/systemc/include_pch/64bit -o ./INCA_libs/irun.lnx8664.13.20.nc/ncsc_run/ncsc_obj/runvstub.o -I$TESTDIR/. -I$CDSROOT/specman -I$TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s -DSN_USE_DYNAMIC_C_INTERFACE -I$CDSROOT/tools/include -I$CDSROOT/tools/inca/include -I$CDSROOT/specman -DNCSC -I$CDSROOT/tools/systemc/include_pch -I$CDSROOT/tools/tbsc/include -I$CDSROOT/tools/vic/include -I$CDSROOT/tools/methodology/OVM/CDNS-2.1.2/sc/src -I$CDSROOT/tools/methodology/UVM/CDNS-1.1d/sc/sc -I$CDSROOT/tools/methodology/UVM/CDNS-1.1d/ml/sc -I$CDSROOT/tools/systemc/include/cci -I$CDSROOT/tools/systemc/include/factory -I$CDSROOT/tools/systemc/include/tlm2 -fPIC -c -x c++  -Wall $TESTDIR/INCA_libs/irun.lnx8664.13.20.nc/specman.13.20.019-s/runvstub.cpp
ncsc_run: *E,TBBLDF: Failed to generate object ./INCA_libs/irun.lnx8664.13.20.nc/ncsc_run/ncsc_obj/runvstub.o
irun: *E,CCERR: Error during cc compilation (status 1), exiting.
 This is part of the content of runvstub.cpp:
// Topmost e module: utmc_reset_sync_config.e
// Generated using seed = 1
// Generated using separator : '.'
// Date: Thu Jan 22 14:28:53 2015
// Specman Elite version: 13.20.019-s
// surefire coverage_off
// No verilog time declaration
module specman;
    //               Stub attributes section
    parameter sn_version_id = 0;   /* Stub checksum */
    parameter sn_version_date = 1010908; /* Stub version */
    parameter sn_use_wave = 1; /* specman_wave module existance*/
    parameter sn_declarations_num = 0; /* The number of reflected HDL declarations */
    parameter sn_port_unification = 2; // 1 for enabled, 2 for disabled
    parameter ncvlog = 1;
    parameter sn_stub_elab = 0;
    //               General section
endmodule /* specman */
module specman_wave;
     /* Errors */
    parameter sn_error_num = 1;
    parameter sn_error_len = 80;
    reg [647:0] sn_err_str1;
     /* Output */
    parameter sn_message_num = 3;
    parameter sn_message_len = 80;
    reg [647:0] sn_msg_str1;
    reg [647:0] sn_msg_str2;
    reg [647:0] sn_msg_str3;
     /* Events */
    parameter sn_event_num = 100;
    reg  sn_emit_event1;
    event  sn_event1;
end
    reg  sn_emit_event2;
    event  sn_event2;
    always @sn_emit_event2 begin
        ->sn_event2;
    end
    reg  sn_emit_event3;
    event  sn_event3;
    always @sn_emit_event3 begin
        ->sn_event3;
    end
    reg  sn_emit_event4;
    event  sn_event4;
    always @sn_emit_event4 begin
        ->sn_event4;
Does anyone knows what is this runvstub.cpp file? And where the source of the problem could be?
  • hannes
    hannes over 11 years ago
    Hi Vinicius,
    I think you should focus on the first error message, which is about some hierarchical path/scope. The ^ may have been in the wrong place, but you need to check that top.asyncrest_n_i exists:
    According to the message above the top scope doesn't exist in SC.
    In your command line you've specified 2 tops:
    Is this correct?
    -hannes
  • Vinicius Alves
    Thank you for your answer. Well, I think I know where the problem may be. The 'top' entity is the VHDL top level entity, while the SC is the reset_sync_top, and both have the asyncrst_n_i. And in order to pass this information to the compilers and elaborators I use the '-top' (which is the same for ncvhdl and ncsc). Is there an way to specify, on the irun command line, which top belongs to which HDL?
  • Vinicius Alves
    I solved part of the problem. By keeping agent() == VHDL of the e units that interface the VHDL DUT the ncsc stop trying to compile the VHDL hierarchies. But keeps returning the second type of error ( class "sc_core::sc_in<sc_dt::sc_logic>" has no member "write" specman_p->ptr_0->asyncrst_n_i.write(uint_to_T(specman_p->ptr_0->asyncrst_n_i.read(),val) ); ). Which does not make sense, because sc_in is a specialized port, and they have write() and read() methods.
  • hannes
    You can use the irun "-sctop" to specify an SC top module. And you should also use the agent() attribute for e units that connect to SC and use "systemc" or "ncsc".
