  2. Functional Verification
  3. Convergence Problem
  • Subscribers 67
  • Views 16147
Convergence Problem
ANALOG DES
ANALOG DES over 11 years ago
Dear All,
Right now, I am using a P channel MOSFET spice model from Toshiba "SSM3J15FU". Based on its datasheet test circuit i just tried to simulate the model.
But i am getting the following error "ERROR(ORPSIM-15138): Convergence problem in transient analysis at Time =  170.4E-06.
         Time step =  266.2E-21, minimum allowable step size =  1.000E-18 ".
Could you please some guide me, how to solve the issue?.
Note : If i use a series gate transistor 1K on its gate control signal, the issue is getting resolved.
I just want to know, how the gate resistor is making its work..
Thanks, US
  • ANALOG DES
    Apologize : Its not a series gate transistor ,a series gate resistor
