  2. Functional Verification
  3. Migration from UVM1.1 to UVM1.2: Problems with Register...
  • Subscribers 69
  • Views 20309
Migration from UVM1.1 to UVM1.2: Problems with Register Viewer + Warnings
zoombarabar
zoombarabar over 10 years ago
Dear All,
I have recently migrated from using UVM 1.1 to UVM 1.2. I have noticed there are additional warnings and problems with UVM Register Viewer in Incisive 14.10.011 version.
UVM_WARNING : reporter [UVM/RSRC/NOREGEX] a resource with meta characters in the field name has been created "regmodel.P1_REGS"
UVM_WARNING : reporter [UVM/RSRC/NOREGEX] a resource with meta characters in the field name has been created "regmodel.P2_REGS"
Additionally, I am not able to view any registers in the register viewer. Any support regarding the same would be very helpful.
Thank you.
Greetings.
Sagar.
  • StephenH
    StephenH over 10 years ago
    Hi Sagar.
    This might be related to which UVM library version you use, can you let us know if it's still a problem when you switch to the CDNS-1.2 (per your other topic on this forum).
    Additionally, can you explain how you generated your UVM_REG class definitions? Did you use a builder tool like reg_verifier, or something else?
    Steve
  • zoombarabar
    Hi Steve,
    this is a new problem I am facing (that I am not able to see the registers in the register viewer) after successful migration to CDNS1.2.
    When I was using 1.1, there was no problem with the UVM register viewer (but with the hdl path definition), but after migration, I could open the register viewer, but with no register content inside. The only changes made was to migrate from UVM1.1d to 1.2.
    Sagar.
  • rkaur9
    rkaur9 over 4 years ago in reply to StephenH
    Hello Stephen,
    i am running one uvm environment on uvm1.1d version , where i am trying to factory override monitor ,but getting error in xrun:
    is it not required to declare another analysis port in overriden class apart  from base monitor:
    please suggest,thnks
    UVM_INFO classes_v/axi_agent.sv(37) @ 0: uvm_test_top.m_env.m_axi_agent [UMONITOR] axi_agent
    UVM_INFO @ 0: uvm_test_top.m_env.m_axi_agent.m_driver [uvm_test_top.m_env.m_axi_agent.m_driver] Build driver
    UVM_INFO classes_v/overide_monitor.sv(22) @ 0: uvm_test_top.m_env.m_axi_agent.m_monitor [OVERRIDE MONITOR BUILD]
    UVM_INFO classes_v/overide_monitor.sv(24) @ 0: uvm_test_top.m_env.m_axi_agent.m_monitor [OVERRIDE MONITOR BUILD] override monitor -----------------------------------------
    Name Type Size Value
    m_monitor override_monitor - @3611
    aport uvm_analysis_port - @3723
    UVM_INFO classes_v/axi_scoreboard.sv(24) @ 0: uvm_test_top.m_env.m_axi_scoreboard [SCOREBOARD] BUILD
    xmsim: *E,TRNULLID: NULL pointer dereference.
    File: /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_port_base.svh, line = 463, pos = 38
    Scope: worklib.uvm_pkg::uvm_port_base#(uvm_pkg::uvm_tlm_if_base#(T,T))::connect
    Time: 0 FS + 13
    Verilog Stack Trace:
    0: function worklib.uvm_pkg::uvm_port_base#(uvm_pkg::uvm_tlm_if_base#(T,T))::connect at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_port_base.svh:463
    1: function worklib.$unit_0x746ee0b2::axi_agent@2763_4.connect_phase at ./classes_v/axi_agent.sv:42
    2: function worklib.uvm_pkg::uvm_connect_phase@685_2.exec_func at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_common_phases.svh:96
    3: function worklib.uvm_pkg::uvm_bottomup_phase@685_2.execute at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_bottomup_phase.svh:108
    4: function worklib.uvm_pkg::uvm_bottomup_phase@685_2.traverse at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_bottomup_phase.svh:81
    5: function worklib.uvm_pkg::uvm_bottomup_phase@685_2.traverse at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_bottomup_phase.svh:61
    6: function worklib.uvm_pkg::uvm_bottomup_phase@685_2.traverse at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_bottomup_phase.svh:61
    7: function worklib.uvm_pkg::uvm_bottomup_phase@685_2.traverse at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_bottomup_phase.svh:61
    8: task worklib.uvm_pkg::uvm_phase@728_2.execute_phase at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_phase.svh:1168
    9: process in worklib.uvm_pkg::uvm_phase::m_iterate_through_phases at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_phase.svh:1997
    NOTE: You may recompile using -linedebug, in case of any discrepency in line/file information in above call stack
    agent.sv
    function void axi_agent::connect_phase(uvm_phase phase);
    m_driver.seq_item_port.connect(m_seqr.seq_item_export);
    -> m_monitor.mon_aport.connect(agent_aport);
    endfunction
