  2. Functional Verification
  3. cover property evaluation error
  • Subscribers 67
  • Views 16085
mahee424
mahee424 over 10 years ago
   I've written the following cover property;
property p1;
    @(posedge clk) (data == 2'h2) ##[1:6]  (data1 == 2'h2);
 endproperty
always@(posedge clk) cover property (p1);
When it hits first time true then afterwards the cover property is not evaluating further. It evaluates only once.
Can anybody help in this regard?
regards,
mahee
  • StephenH
    StephenH over 10 years ago
    There is no error here. Cover properties by default aren't evaluated once they have been completed, in order to improve simulation speed. You can force the simulator to always evaluate the properties by adding the following irun switch: -abvrecordcoverall.
  • mahee424
    Thanks Stephen...the switch is working fine and i observed some reduction in simulation speed which is intended.
