  2. Functional Verification
  3. Any alternative way to connect an internal DUT's signals...
  • Subscribers 67
  • Views 7985
Any alternative way to connect an internal DUT's signals to TB's interface's modport?
Rama Kishore
Rama Kishore over 10 years ago
I have a DUT with a controller and memory inside it - connected via an interface-protocol, say AXI.
Then I have a TB with DUT_inst  & Interface_inst. The purpose of this interface_inst is to monitor the AXI interface to report the wiggling to an UVM component (using virtual interface binding). This interface_inst provides multiple modports for both monitoring + driving purposes.
For connecting the DUT signals to interface_inst, I used MULTIPLE "assign" statements. This is working fine. Now my question is, if there is an easy way to connect the DUT signal to the interface_inst in a single statement, without these multiple assign statements. Something like connecting the DUT signals to interface_inst, while instantiating it in TB itself.
Note:  The controller/memory are legacy verilog modules, which do not have modports on them. They just simply have legacy ports, instead.
Sample code snippet of my scenario is shown below:
/*** CLKGEN module ***/
module my_clkgen (output logic clk);
endmodule
/*** CONTROLLER module ***/
module my_ctrlr (output logic o, input logic i);
endmodule
/*** MEMORY module ***/
module my_mem (output logic o,input logic i);
endmodule
/*** INTERFACE definition ***/
interface my_intf (input clk);
  logic         c_to_m;
  logic         m_to_c;
  modport   ctrlr_modport (input c_to_m, output m_to_c);   // Modport for DUT's controller
  modport   mem_modport (output c_to_m, input m_to_c); // Modport for DUT's memory
  modport   mon_modport (input c_to_m, input m_to_c);    // Modport for passive monitor
endinterface
/*** DUT module = CONTROLLER + MEMORY ***/
module my_dut;
   wire                 c_to_m_net;
   wire                 m_to_c_net;
   my_ctrlr           ctrlr_inst(.o(c_to_m_net) , .i(m_to_c_net)); // CONTROLLER Instance
   my_mem        mem_inst (.i(c_to_m_net) , .o(m_to_c_net)); // MEMORY Instance
endmodule
/*** TB module = DUT + CLKGEN + INTERFACE ***/
module my_tb;
   wire                 clk_net;
   my_dut           dut_inst();                                                          // DUT instance
   my_clkgen     clkgen_inst(.clk(clk_net));                              // CLKGEN instance
   my_intf           intf_inst (.clk(clk_net));                                    // INTERFACE instance
   assign            intf_inst.c_to_m = dut_inst.c_to_m_net;      // Connect DUT signal to Interface
   assign            intf_inst.m_to_c = dut_inst.m_to_c_net;      // Connect DUT signal to Interface
   //my_intf intf_inst (.clk(clk_net),
   // .mon_modport.c_to_m(dut_inst.c_to_m_net),                 //** IS SOMETHING LIKE THIS POSSIBLE **??
   // .mon_modport.m_to_c(dut_inst.m_to_c_net)                  //** IS SOMETHING LIKE THIS POSSIBLE **??
endmodule
I'm new to SV HDL language. Will really appreciate your quick inputs. Thanks.
-Regards
Kishore
  • tpylant
    tpylant over 10 years ago
    Can you use ports on your DUT?
    module my_dut (input c_to_m_net, output m_to_c_net);
    endmodule
    module my_tb;
       wire          clk_net;
       my_dut        dut_inst(.c_to_m_net(intf_inst.c_to_m), .m_to_c_net(intf_inst.m_to_c)); // DUT instance
    endmodule
  • Rama Kishore
    No Tim, DUT is a well integrated module, where adding new ports is too much of an effort. The DUT scenario I quoted was a very simplified version of a realistic design, where we may need to monitor several AXI/APB/.. interfaces. So bringing them all over up to the TB layer isn't a good idea.
    Also if the signal to be monitored is very deeply nested in the DUT hierarchy, its even more effort to get that via port up to the TB layer.
