  2. Functional Verification
  3. UVM_CMDLINE_PROCESSOR working issue
  • Subscribers 68
  • Views 18441
mahee424
mahee424 over 10 years ago
  I'm trying to get value from command line using UVM_CMDLINE_PROCESSOR but couldn't extract the value from command line with the following trail code;
class onscl extends uvm_object;
    extern function new(String name="onscl");
endclass
function onscl::new(string name = "onscl");
     uvm_cmdline_processor l_cmd = uvm_cmdline_processor::get_inst();
     string onscl_inputs[$];
     super.new(name);
     void'(l_cmd.get_arg_values(.match("+LENGTH="),.values(onscl_inputs)));
     foreach(onscl_inputs[i])
     begin
        `uvm_info(get_name(),$psprintf("ONSCL-INPUTS[%0d]:%s",i,onscl_inputs[i]),UVM_LOW)
     end
endfunction
       Please share your suggestion  for getting variable value from command line.
mahee
  • StephenH
    StephenH over 5 years ago in reply to Freedi +1
    Works for me: // clp.sv `include "uvm_macros.svh" module clp; import uvm_pkg::*; class clptest extends uvm_test; `uvm_component_utils(clptest) function new (string name="clptest", uvm_component parent…
  • muffi
    muffi over 5 years ago in reply to Freedi +1
    Make sure that you do not have the " -define UVM_NO_DPI " or " +define+UVM_NO_DPI " enabled. These will disable the Command Line Interface.
  • Freedi
    Freedi over 5 years ago
    Having the same issue,couldn't extract the value from command line with flowing code ,
    function void start_of_simulation_phase(uvm_phase phase);
        int num;
        uvm_cmdline_processor clp;
        string myarg ;
        clp = uvm_cmdline_processor::get_inst();
        num = clp.get_arg_value("+myarg=",myarg);
        if (num)
        begin
            $display("****************");
            $display("STRING=%0s",myarg);
        end
    endfunction
  • StephenH
    Works for me:
    // clp.sv
    module clp;
    import uvm_pkg::*;
    function new (string name="clptest", uvm_component parent=null);
    int num;
    string myarg ;
    super.new(name,parent);
    if (num)
    begin
    end
    endfunction
    endclass
    initial run_test("clptest");
    endmodule
    % xrun clp.sv -uvmhome CDNS-1.1d +myarg=abcd
    TOOL: xrun 20.10-a001: Started on Nov 23, 2020 at 13:33:27 GMT
    xrun: 20.10-a001: (c) Copyright 1995-2020 Cadence Design Systems, Inc.
    Loading snapshot worklib.clp:sv .................... Done
    SVSEED default: 1
    <snip>
    (Specify +UVM_NO_RELNOTES to turn off this notice)
    STRING=abcd
    UVM_INFO @ 0: reporter [RNTST] Running test clptest...
  • muffi
    Make sure that you do not have the "-define UVM_NO_DPI" or "+define+UVM_NO_DPI" enabled. These will disable the Command Line Interface.
  • Freedi
    Freedi over 5 years ago in reply to muffi
    thanks solved now , that was the issue.
