  2. Functional Verification
  3. licqueue is not working
  • Subscribers 67
  • Views 20783
ReubenMijares
ReubenMijares over 10 years ago
I put -licqueue in irun but I noticed that it is not putting it in the queue.
I can still have the license checkout error below:
ncsim: *F,NOLICN: Unable to checkout license for the simulation. (flag - 42) 'lic_error -18'.
I can't complete all the testcases of my regression because of this license issue.
Do you think there's something wrong with how I use the -licqueue option, that's why it still can't get in the queue?
Reuben
  • ReubenMijares
    Oh wait. When I run a single testcase, it is waiting in the queue. The problem is when I'm doing it in the regression (not single testcase).
    It could be on the script. The script is made to implement a single compile. After the compile, there's a loop that will simulate all the testcases.
    I put the -licqueue on the compile or along the -elaborate option. Maybe I should put it inside the loop where each testcase is being simulated?
    I will try it and see if it will work. =)
  • StephenH
    StephenH over 10 years ago
    You need to pass -licqueue to each irun call. Note that compilation and elaboration do not require a licence.
  • ReubenMijares
    Thanks! It's working now!
    Just as you said, I put the -licqueue option inside the loop.
    Reuben
