  2. Functional Verification
  3. HAL: turn on a rule in the design_info file
  • Subscribers 67
  • Views 15258
maraninchijp
maraninchijp over 10 years ago
I am trying to turn on a rule, that is turned off into the def file, into the design_info file for a certain part of the module
for instance, in the def file, I have
INSTNM {level=4} {off}
and in the design_info file :
lint_checking designunit = chip_top
 INSTNM {pattern="i_*"} on ;
with this configuration, I will never have a warning reported by the tool, as it seems it considers the rule INSTNM always off
but, if I do the opposite, turn on the rule in the def file and turn it off in the design_info file, I will have the expected result.
we can deduce that the design_info file is well taking into account by the tool.
note that, I have the same problem with all the rules I try to turn on in the design_info file, even rules without 'pattern' paramter
any ideas are welcome,
thanks
jean-pascal
