  2. Functional Verification
  3. ADDRESS Mapping issue in RAL in UVM
  • Subscribers 66
  • Views 17118
mahee424
mahee424 over 9 years ago
    I've the following declaration in reg_block;
class reg_block extends uvm_reg_block;
       i2c_map = create_map("i2c_map",'h0,'h1,UVM_LITTLE_ENDIAN);
       i2c_map.add_reg(u_ControlReg1,8'h00,"RW");
      i2c_map.add_reg(u_ControlReg2,8'h01,"RW");
   lock_model();
endclass
During simulation,I observed the following issue;
UVM_WARNING /home/moduru/Documents/samples/uvm_ex/uvm_lib/CDNS-1.2/sv/src/reg/uvm_reg_map.svh(1633) @ 0: reporter [RegModel] In map 'm_i2c_reg_block.i2c_map' register 'm_i2c_reg_block.u_ControlReg2' maps to same address as register 'm_i2c_reg_block.u_ControlReg1': 'h1
Please let me know how to resolve this?
regards,
omahee
  • mahee424
    The thing happening for the above issue is;
    Since the register size is 16 bit wide; we've to configure register_map n_bytes to 'h2 instead 'h1.
    After doing this change the above WARNING goes off.
    regards,
    omahee.
