  2. Functional Verification
  3. Post place-and-route SDF back-annotation fails when using...
  • Subscribers 67
  • Views 17566
Post place-and-route SDF back-annotation fails when using Verilog multi-dimension array ports and internal nets
Pacher Luca
Pacher Luca over 10 years ago
Dear all,
I'm working on a digital design with a top-level module that requires to declare some I/O ports with a combination of Verilog packed and unpacked array syntax in order to have a more compact and less error prone RTL code.
As an example, let suppose that my top-level module contains a port declaration and a sub-module instantiation such as
module MyModule(
   input  scalar_input,
   output scalar_output,
   output [9:0]  bus_output,
   output [9:0]  bundle_of_bus [31:0] ,
   other ports...  ) ;
   subModuleName   instanceName(
     .bus_output(bus_output), .bundle_of_bus(bundle_of_bus), other connections...) ;
  other stuffs here ...
endmodule
RTL simulations, synthesis and place-and-route flows work fine up to the final netlist and SDF export.
Unfortunately, when after place-and-route I try to perform gate-level simulations including SDF information the delay back-annotation fails. In fact all ports in the SDF file generated by EDI are exploded and escaped in form of
bundle_of_bus\[31\][0]
bundle_of_bus\[31\][1]  etc.
The gate-level Verilog netlist generated by EDI explodes instead the top-level module port declaration with the syntax
[9:0] \bundle_of_bus [0]
[9:0] \bundle_of_bus [1] etc.
whereas automatically-generated internal connections between I/O ports and instantiated cells use a condensed port-mapping like
instanceName( .\bundle_of_bus[31] ( \bundle_of_bus[31] ) ,
                       .\bundle_of_bus[30] ( \bundle_of_bus[30] )  etc. )
As a result of such a mess the SDF annotation fails, because Incisive can't properly access delays for these signals.
So the questions are :
1. is SDF annotation definitely unsupported by the Incisive simulator with such Verilog port declarations/internal connections ?
2. is there a way to fix this already during synthesis or place and route without editing the original RTL ?
I can't believe that Cadence tools don't support this syntax with its native Verilog language! :-)
Thanks in advance
Luca
  • Pacher Luca
    OK, maybe I solved myself. By TABbing some RTL Compiler synthesis commands I've found the syntax
    set_attribute  hdl_flatten_complex_port    true   /
    With such an option all multi-dimension Verilog ports are "flattened" into unique buses already during synthesis, thus avoiding SDF issues during back-annotation. The new gate-level interface with outside the world (e.g. the testbench) changes, but this is a minor issue.
    Solved!
    Ciao
