  2. Functional Verification
  3. simvision, get when a cover assertion was hit
  • Subscribers 67
  • Views 16926
kkhsieh
kkhsieh over 10 years ago
Hi all,
In simvision, given an assertion, is there a way to get all the timestamps when the assertion was hit?
Thanks.
  • Doug Koslow
    Doug Koslow over 10 years ago
    Hi Kuokai,
    One way to do this would be to probe the assertion activity as transactions (i.e. "probe -create -assertions -transaction <assertion>"), and then use the Transaction Stripe Chart window in SimVision to view the activity of the assertion by simulation time.  (You can even export the data to a .CSV file.)
    Good luck!
    - Doug
  • kkhsieh
    Hi Doug,
    It works. Do you know any method such that I can convert them to CSV in batch mode?
    Thanks for the reply.
    Best,
    -Kuokai
  • Doug Koslow
    Hi Kuokai,
    SimVision itself is not a pure batch mode tool.  However, you can use the Transaction Explorer tool (TXE) to extract information about transactions and write them to a file in batch mode.  (You can check the Incisive docs regarding this tool.)
    Thanks.
    - Doug
  • kkhsieh
    Hi Doug,
    Thank you for the help. Now I'm able to get the information via TXE batch mode!
    Sincerely,
    - Kuokai
