  2. Functional Verification
  3. simvision: how to add all signals in design to waves
  • Subscribers 66
  • Views 24886
SysTom
SysTom over 9 years ago
Hello,  What are the fewest commands to add all signals in design to waveform viewer?  Thanks, SysTom
  • Doug Koslow
    Doug Koslow over 9 years ago
    Hi Thomas,
    That is an interesting challenge. ;-)
    Please try the following SimVision commands (assuming you have the Design Browser and Waveform windows opened):
    browser select deep <top_scope_name>
    waveform add -selected
    Please be careful about adding too many signals into the waveform. That can introduce performance issues.
    Good luck...
    - Doug
  • SysTom
    Hi Doug,
    Thank you for your feedback. Yes, that seems to work. I also found I could do this:
    database -open waves -into waves.shm -statement -default
    scope -set {top}
    probe -create -all -depth all -waveform
    Both methods added a much more significant simulation burden than I had anticipated - even with my relatively small design/TB.
    Thanks again,
    Tom
  • Doug Koslow
    Hi Tom,
    Yes, enabling statement trace recording (database -statement) will definitely significantly degrade simulation performance. I would avoid doing that if at all possible.
    I would also suggest probing depth to "to_cells" level instead of "all", unless you really need to probe within cells.
    Thanks.
    - Doug
  • SysTom
    Hi Doug,
    Thanks for the tip: I tried to_cells. In my case it was quicker to load the waves but performance was still degraded somewhat (less than 'all'). I'll look into a way to cherry-pick was I need a bit better.
    ~Tom
