  2. Functional Verification
  3. UVM variables in waveform aren't displayed instantly
  • Subscribers 67
  • Views 2890
RenePi
RenePi over 10 years ago
Hello everyone,
I am using a basic UVM Layered Sequences example which is also introduced here:
https://www.doulos.com/knowhow/sysverilog/uvm/easier_uvm_guidelines/layering/
My problem is that when I expand the "Monitor" (b2amon/c2bmon) and the variables, the Simulation, which lasts for only 600 ns, becomes pretty unuseful, because I can hardly zoom in and out or move back and forth in time without lags causing me to wait several seconds until the waveform is updated.
Right now I have just like 4 variables and short simulation time, so probably if I add more variables and increase the simulation this effect would cause the whole simulation to be useless, if I can't move around inside the waveform!
Has anyone of you already expierenced similar issues and might want to help me solving this? I really don't know what's the problem with that?!
Would really appreciate your support!
Thanks a lot in advance,
René
  • RenePi
    Somehow this problem appeared when using version 14.20.003, cause we have now updated to 15.20.003 and now everything works as fast as it should!
