  2. Functional Verification
  3. Quickly schematic-viewing a gates file
  • Subscribers 67
  • Views 20464
Almendrico
Almendrico over 10 years ago
Hi all,
I wonder whether it is possible to quickly open an schematic viewer to display a digital gates file
Given I have a .vg (or .v) file and a verilog gates libraries, is there any quick way to open an schematic browser via the command shell ? My only option at the moment is to call simvision and then, once there, send the design to the schematic viewer... Is there something faster, something like below:
$: simvision myfile.vg -y mylibs/tsmc18
Any comments welcome
  • StephenH
    StephenH over 10 years ago
    SimVision has a number of layouts built in that you can specify at the command line, but sadly not a schematic-only one. You can define your own layouts though, so open sSimVision once (no design needed), and open the Schematic Tracer window, close all other windows, and go to the menu Window->Layout->Save and save it as "gates".
    Now you can do this from teh command line:
    irun myfile.vg -y mylibs/tsmc18 -access +rwc -createdebugdb -gui -layout gates
    Explanation: irun is the one-stop front-end which will compile and elaborate your design; -gui opens simvision, and -layout gates tells it to open your saved layout. "-access +rwc" enables schematic connectivity tracing (which would be disabled by default for performance reasons). "-createdebugdb" tells the elaborator to save a special debug database to make SimVision load and trace shcematics quicker.
  • Almendrico
    Thanks Steve
    Couple of comments:
    * irun also needs a timescale directive
    * once the layout windown opens, it is still needed to select the block and 'send to schematic viewer'
    too much setup work involved here ... not exactly what I was looking for
  • StephenH
    The timescale is only needed if your design has a mixture of modules with and without timescales. If you're not interested in simulating and only want to browse the schematic, just invent a timescale: "-timescale 1ns/1ns".
  • Almendrico
    I know, I was only saying that there are too many steps involved in just 'viewing' a gates file
    Thanks Stephen
  • Doug Koslow
    Doug Koslow over 10 years ago
    In addition to the approach using a layout, one could write a script that passes the top module of the design to the schematic and fills it.  Content of the "schematic_fill.tcl" script is below.
    You would invoke it like:
    irun myfile.vg -y mylibs/tsmc18 -simvisargs "-schematic -input schematic_fill.tcl" +gui -s -access +rwc -createdebugdb
    schematic_fill.tcl:
    # Get the current design, add it to the schematic, and fill it.
    array set info [simcontrol info]
    set scope [lindex [split $info(Design) ":."] 1]
    # Attempt to select it.
    select set -type scope $scope
    # Check if we have something selected.
    if {[select get -type scope] == ""} {
        # Nothing selected. Try selecting ":" scope for VHDL.
        set scope ":"
            error "Unable to extract top level scope from design."
    # Add the selected scope to the schematic
    schematic add -selected
    # Fill the scope
    schematic invoke Edit>FillModules
    Please give this a try.
    Thanks.
    - Doug
