  2. Functional Verification
  3. ncsim problem in AMS simulation
  • Subscribers 67
  • Views 17319
geovol
geovol over 10 years ago
Hi all,
I am facing a problem when I am trying to simulate verilog code along with analog blocks using the AMS simulator. This is how the story goes:
Initially, with IUS-8.2 installed I was able to simulate simple AMS designs. However, in other AMS designs I was getting an undefined error, which was prompting me to contact Cadence. After searching online, I figured out this had to do with IUS version which was too outdated. Therefore, I asked the sys admin to install INCISIVE-15.20.008. With this package, for the same design I was not able to compile 4 modules from connectLib. For example, for one of the modules I am getting the following error:
ncvlog: *E,NOTSTT (/proj/cad/cadence/incisive-15.20.008.lnx86/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/ER_bidir/module/verilog.vams,118|15): expecting a statement [9(IEEE)].
I went back to IUS, by including (softinclude) the appropriate cds.lib file (for IUS) in my cds.lib file. However, when I am trying to simulate the design that I was initially able to simulate with IUS, i.e. before installing INCISIVE, now I get an error displaying:
ncsim: *E,MSSYSTF (/proj/cad/cadence/incisive-15.20.008.lnx86/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/L2E_2/module/verilog.vams,110|18): User Defined system task or function registered during elaboration and used within the simulation has not been registered during simulation.
It seems that ncsim is trying to compile a module from the INCISIVE installation. Do you have any ideas on how can this be possible?
I double checked that ncsim runs from IUS and not INCISIVE path:
which ncsim
/proj/cad/cadence/ius-8.2.lnx86/tools/bin/ncsim
Let me notice that my configuration is:
IC6.1.5-64b.500.14
MMSIM 13.11
Thank you,
George
  • tpylant
    tpylant over 10 years ago
    Not sure if this is still a problem but if it is, can you append your compile command? Are you manually trying to compile in the connect module or is that message from something the simulator is pulling in on its own?
    The second error might be a relic of switching simulator versions. Try adding "-clean" to the irun command to make sure it starts clean.
    Tim
