  2. Functional Verification
  3. AmsDmv command line problems
  • Subscribers 67
  • Views 14943
Sampoorna
Sampoorna over 10 years ago
I recently started using the amsDmv tool to compare results from two different cell views. I was trying to open amsDmv from command line using the command "amsDmv" in the UNIX terminal, however I get the error "command not found." I tried invoking the command from my cds directory and from the path in which my dmv setup was located (although that path should not be necessary). Can you please help me out in finding what the problem could be?
  • tpylant
    tpylant over 10 years ago
    Make sure you have <IC616 install>/tools/dfII/bin in your path.
    Tim
