  2. Functional Verification
  3. AmsDmv issue with measured results field
  • Subscribers 67
  • Views 14235
Sampoorna
Sampoorna over 10 years ago
I used the amsDmv to compare ADE-XL results for two different config views, and after the completion of the simulation, I observe that the measured results field says "No valid measured results found" when I check the box next to "Validate Measured Results" although the waveform signals field shows a pass or fail. What could be a possible reason for this?
Sampoorna
