  2. Functional Verification
  3. [SV] Constraint solver issue
  • Subscribers 67
  • Views 20642
stanzani
stanzani over 10 years ago
hello
below is a class I use for randomize some settings of a ADC controller RTL.
I got the following error
stop -create -name Randomize -randomize
Created stop Randomize
assert ( gpadc_settings0.randomize(lo_thre,hi_thre)); // with c_hilo_thre);
ncsim: *W,SVRNDF (./my_task.v,315|41): The randomize method call failed.
Observed simulation time : 22747513300 PS + 0
ncsim: *W,RNDOCS: These constraints contribute to the set of conflicting constraints:
shortint'(men.VBUSOUT ) + shortint'(men.CHPWR ) + shortint'(men.VBUSIN ) + shortint'(men.VSYS ) >= men_num ; (/proj/pm8282d1/wa/stanzani/pm8282d1_des/r1.0.0/digital/top/dig/sim/test_board/tb/gpadc_pkg.sv,761)
ncsim: *W,RNDOCS: These variables contribute to the set of conflicting constraints:
state variables:
men_num (4) [/proj/pm8282d1/wa/stanzani/pm8282d1_des/r1.0.0/digital/top/dig/sim/test_board/tb/gpadc_pkg.sv, 747]
22747513300 PS + 0 (stop Randomize: Randomize failure)
I do not understand where the conflict is. It looks to me than men and *thre are completeely independent variables which are randomized separately but surely there is something I do not understand about the constraint solver operation.
typedef struct packed {
bit M15;
bit M14;
bit M13;
bit TINT; //12
bit IVBUSOUT; //11
bit VBUSOUT; //10
bit PMODE; // 9
bit GPADC0; // 8
bit CHPWR; // 7
bit VSYS; // 6
bit VBATC2; // 5
bit VBATC1; // 4
bit VBATSNSN; // 3
bit VBATSNSP; // 2
bit VBUSIN; // 1
bit M0; // 0 LSB
} t_meas_en_reg;
class cl_gpadc_settings;
rand t_meas_en_reg men;
byte unsigned men_num=4;
randc bit[3:0] slow; // slow down the sampling clock frequency
rand bit [11:0] meas_off;
randc byte unsigned lo_thre[9];
randc byte unsigned hi_thre[9];
rand bit [3:0] stretch; // additional setting time for the acq.phase
constraint c_men {
men.M0==0;
men.M13==0;
men.M14==0;
men.M15==0;
shortint'(men.IVBUSOUT) + shortint'(men.TINT ) + shortint'(men. PMODE ) + shortint'(men.GPADC0 ) +
shortint'(men.VBATC2 ) + shortint'(men.VBATC1) + shortint'(men.VBATSNSN) + shortint'(men.VBATSNSP) +
constraint c_hilo_thre
foreach(lo_thre[i])
lo_thre[i] inside {[5:64]};
foreach(hi_thre[i])
hi_thre[i] inside {[128:255]};
// function new (input shortint unsigned min_meas);
// min_meas_en_num = min_meas;
// endfunction:new
function new ();
endfunction:new
  • TAM1
    TAM1 over 10 years ago
    Good morning.
    Whenever a class_handle.randomize() function returns, the class needs to be in a state where every constraint is satisfied. This is true whether you are randomizing the class object as a whole, or randomizing one or more individual fields in that class. In this instance, you are randomizing the members lo_thre and hi_thre. So the rest of the members are left unchanged. But before the randomize can return, every constraint is examined. From the error message, it looks like the values of men and men_num violate constraint c_men going into the call and thus the call cannot return successfully.
    • You can make sure that the class object is in a legal state before randomizing individual fields.
    • You can use constraint_mode(0) to disable the constraints that aren't currently applicable.
    • You can use the inline (not class based) randomize call to randomize those fields individually. e.g. success = std::randomize(lo_thre with ...);
    TAM
    o_thre,hi_thre
    o_thre,hi_thre
    o_thre,hi_thre
