  2. Functional Verification
  3. Problem with user define net types resolution functions
  • Subscribers 67
  • Views 20282
jach78
jach78 over 10 years ago
Hi all,
I have defined a net in this way:
typedef struct{
real V;
real I;
} EEstruct;
function automatic EEstruct res_EE(input EEstruct driver[]);
foreach(driver[i]) begin
to debug my resolution function I need to know which driver is driving the net. How can I know this information?
what kind of data structure driver is? Is there a name field in the driver element or somthing like that?
Another questione,
In the testbench I assign the net in the following way:
assign mynet = '{1.0,2.0}; // is this correct?
assign mynet2 = '{`wrealZState, `wrealZState};
Are this assignment correct?
Jack
  • tpylant
    tpylant over 10 years ago
    You can use $display, $resolved_wudn_name and $resolved_wudn_drivers within the resolution function to help you debug.
    Those assignments will work.
    Tim
  • jach78
    Hi Tim,
    can you provide a simple example on how to use those method?
    Or link me some resources where I can read the parameters these functions accepts as input and what they return?
    Many thanks,
    Jack.
  • tpylant
    //user-defined data type instruction
    typedef struct  {
      real opcode;
      real val;
    } instruction;
    // user-defined resolution function FUNC
    function automatic instruction FUNC(input instruction drivers[]);
      $display("\nNet %s is being Resolved\n", $resolved_wudn_name());
      $resolved_wudn_drivers;
      foreach (drivers[j])
    $display ("Time: %f,  FUNC: drivers[%d](opcode= %f, val = %f}", $realtime, j, drivers[j].opcode, drivers[j].val);
    FUNC = '{4.1, 4.2};
    endfunction
    // A nettype declaration with datatype and resolution function
    nettype instruction net_r_inst with FUNC;
    module top;
      net_r_inst  I1;
      instruction I2 = '{1.1, 1.2} ;
      instruction I3 = '{2.1, 2.2} ;
      assign I1 = I2;
      assign I1 = I3;
      initial begin
    #0 $display("\n time: %f I1 = %p, I2 = %p, I3 = %p", $realtime,I1, I2, I3);
    #1 $display("\n time: %f I1 = %p, I2 = %p, I3 = %p", $realtime,I1, I2, I3);
        #5 $finish;
      end
    endmodule
    Output
    Net top.I1 is being Resolved
    I1.........net(nettype net_r_inst) struct {
                  real opcode = 0
                  real val = 0
               } = '{opcode:0, val:0}
       '{opcode:0, val:0} <- (top) assign I1 = I2
       '{opcode:0, val:0} <- (top) assign I1 = I3
    Time: 0.000000,  FUNC: drivers[          0](opcode= 0.000000, val = 0.000000}
    Time: 0.000000,  FUNC: drivers[          1](opcode= 0.000000, val = 0.000000}
                  real opcode = 4.1
                  real val = 4.2
               } = '{opcode:4.1, val:4.2}
       '{opcode:1.1, val:1.2} <- (top) assign I1 = I2
       '{opcode:2.1, val:2.2} <- (top) assign I1 = I3
    Time: 0.000000,  FUNC: drivers[          0](opcode= 1.100000, val = 1.200000}
    Time: 0.000000,  FUNC: drivers[          1](opcode= 2.100000, val = 2.200000}
     time: 0.000000 I1 = '{opcode:4.1, val:4.2}, I2 = '{opcode:1.1, val:1.2}, I3 = '{opcode:2.1, val:2.2}
     time: 1.000000 I1 = '{opcode:4.1, val:4.2}, I2 = '{opcode:1.1, val:1.2}, I3 = '{opcode:2.1, val:2.2}
    Simulation complete via $finish(1) at time 6 NS + 0
    ./top.sv:13       #5 $finish;
  • jach78
    Hi Tim,
    thank you very much for your help, that's what I was asking for.
    Best regards,
    Jack.
  • jach78
    Hi Tim,
    when I use the $resolved_wudn_drivers, as in your example, I receive the following error:
    ncsim: *E,OBJACC: Object must have read and connectivity access: tb_instance_name.VX
    Do you have any advice on the root cause?
    Thank you very much and best regards,
    Jack.
  • tpylant
    Try adding "-access rwc" (or "-debug" which does the same thing) to the irun command line. This will open up read, write, and connectivity access. However, it will affect performance so you want to only add it during debug.
    Tim
