  2. Functional Verification
  3. Generate an index to an ungeneratable list of struct
  • Subscribers 67
  • Views 17002
Yanir
Yanir over 10 years ago
How do i generate an index to a list of struct with constraints.
For example i have the following struct and list:
struct se_cte_free_mem_area_s
!address_start : u64_t;
!address_end : u64_t;
area_size : u64_t;
!free_mem_areas : list of se_cte_free_mem_area_s;
and i want to generate on the fly an index to the list with constraint (For example where  address_start <= address_x <= address_end)?
Yanir.
  • StephenH
    StephenH over 10 years ago
    Do the ranges of start...end overlap or is free_mem_areas[0].address_start always the lowest address and free_mem_areas[free_mem_areas.size()-1].address_end always the highest?
    Note that recent versions of Specman have support for a "set" datatype so you can model your start...end addresses as a list of sets and constrain the index to be within that list. Look at "The set type" in the Specman e user's guide. Here's an example from the docs which illustrates the idea.
    struct s {
    foo() is {
    var s1: set;
    var s2: set = [3..7, 10..13]
    print 5 in s2; // prints TRUE
    print 8 in s2; // prints FALSE
    s1 = s2; // s1 is [3..7, 10..13]
    s2 = [4..5]; // s1 is not changed
    print s1 in s2; // prints FALSE
    print s2 in s2; // prints TRUE
    var x: int;
    gen x keeping {it in value(s2)}; // x may become 4 or 5
    Note also that if you're doing address management, vr_ad has excellent support for allocating memory ranges (programmatically or randomly). If you're interested, PM me your corporate email address and I'll send you a copy of a tutorial that I wrote on the subject.
  • Yanir
    Yanir over 6 years ago in reply to StephenH
    I would like to receive a tutorial on vr_ad. My corporate email is yanir.davidzada@intel.com
  • Efrat
    Efrat over 6 years ago in reply to Yanir
    hi, Yanir.
    sending you the material, to your email
