  2. Functional Verification
  3. Generate min/max values on modified bitslice scalar
  • Subscribers 67
  • Views 936
Yanir
Yanir over 10 years ago
How do i generate min/max values on modified bit slice scalar?
For example i trying to do the following and Specman fail during generation:
gen_address(alignment : u64_t) : u64_t is
var bits_to_zero : int;
case (alignment)
2 : { bits_to_zero = 0; };
4 : { bits_to_zero = 1; };
8 : { bits_to_zero = 2; };
16 : { bits_to_zero = 3; };
32 : { bits_to_zero = 4; };
64 : { bits_to_zero = 5; };
128 : { bits_to_zero = 6; };
256 : { bits_to_zero = 7; };
512 : { bits_to_zero = 8; };
1024: { bits_to_zero = 9; };
2048: { bits_to_zero = 10; };
4096: { bits_to_zero = 11; };
gen result keeping
it[read_only(bits_to_zero):0] == 0;
soft it[read_only(bits_to_zero)] == select {
40: min;
40: max;
20: others;
soft it[63:32] == select {
40: 0xAAAAAAAA;
40: 0xBBBBBBBB;
20: others;
