  2. Functional Verification
  3. Compile time ,elaboration time and simulation time calculation...
  • Subscribers 66
  • Views 21348
Compile time ,elaboration time and simulation time calculation while running a test
mahee424
mahee424 over 8 years ago
       I'm looking for knowing on how to get the information on how much time consumed during compile,elaboration and simulation phases for any test in IRUN.
If there is any switch please provide some suggestions?
Mahesh
  • StephenH
    StephenH over 8 years ago
    Hello Mahesh.
    You can use the irun options "-status -status3" to get the time per step. It then reports messages in the format of
    ncsim: Memory Usage - 31.0M program + 81.3M data = 112.2M total (112.7M Peak)
    ncsim: CPU Usage - 0.1s system + 0.3s user = 0.5s total (0.8s, 59.0% cpu)
    Where "ncsim" could also be "ncvlog" or "ncelab".
  • mahee424
    Hello Stephen,
    Thanks for the suggestion..it's helped a lot in improving CPU usage at each stage.
    Mahesh
