  2. Functional Verification
  3. VPI: vpi_iterate does not access internal nets in SV code...
  • Subscribers 67
  • Views 16533
VPI: vpi_iterate does not access internal nets in SV code despite vpiNet
Sporadic Crash
Sporadic Crash over 8 years ago
my vpi_iterate cannot access internal signals but the ports. Please help. Cadence Incisive version is 15.20.017.
I have following module (in SystemVerilog):
module my_block (
input logic a,
input logic b,
input logic c,
output logic z
logic intermediate_signal;
assign intermediate_signal = a & b;
assign z = intermediate_signal & c;
endmodule
I have written a VPI routine to grab all the signals in the block above:
#include <sv_vpi_user.h>
#define NULL 0
int dut_dump (char *str) {
vpiHandle handle_scope_iterator;
vpiHandle handle_scope_object;
s_vpi_value object_value;
vpi_printf ("Scope: %s\n", str);
object_value.format = vpiBinStrVal;
handle_scope_iterator = vpi_iterate(vpiNet, vpi_handle_by_name(str, NULL));
while (handle_scope_object = vpi_scan (handle_scope_iterator)) {
 vpi_get_value (handle_scope_object, &object_value);
 vpi_printf ("net: %s, value %s\n", vpi_get_str(vpiName, handle_scope_object), object_value.value.str);
 return (0);
When I instantiate the block my_block in a testbench and call the dut_dump in the testbench,
module tb ();
my_block dut (...);
initial begin
dut_dump("tb.dut");
end
endmodule
Simulation gives following:
ncsim> run
Scope: tb.dut
net: a, value 1
net: b, value 1
net: c, value 1
Memory Usage - 29.3M program + 25.1M data = 54.4M total
It does not iterate the internal signal intermediate_signal.
  • Where is my mistake?
  • Is VPI implementation for SystemVerilog in Incisive extended?
  • Do I use the correct header name?
  • Do I need a special switch to compile/elab/sim at Incisive?
  • Tudor Timi
    Tudor Timi over 8 years ago
    You're not seeing 'intermediate_signal' because it isn't a net, but a variable. Simplistically put, nets are wires that connect variables. I'm not sure what the implicit rules are for describing whether a signal is a net or a variable, but I would assume that 'input logic a' is equivalent to 'input logic wire a', whereas inside the module body 'logic intermediate signal' is equivalent to 'logic var intermediate signal'.
    You can find more info about nets and variables in section '6.5 Nets and variables' of the 2012 LRM.
  • Sporadic Crash
    I have found the reason by adding further debug which prints vpiTypes.
    For SystemVerilog the implementation of the version of the Cadence Incisive simulator I have used is that:-
    - the object types of logic for internal nets and output ports are of vpiType "vpiReg" (logic is a "reg" here, backward compatibility to Verilog-2001 etc)
    - the object types of logic for input ports are of vpiType "vpiNet" (logic is a "wire" here, backward compatibility to Verilog-2001 etc)
    That's why I could also not see the output port (because internally it was a "reg" even though decl was "logic"and driven by an "assign".
    The LRM 1800-2009 page 919 has more information about this (Part Three, "APIs", "37.17 Variables")
    Another simulator could return other types.
    So iterate for each of vpiType. Now I can see any object I am looking for.
    Thanks for your explanation though!
  • Tudor Timi
    I would assume that the rules as to whether a simple 'logic' is treated as a 'reg' (i.e. variable) or 'wire' (i.e. net) are unambiguously described in the LRM and that a different simulator would return the same thing.
