  2. Functional Verification
  3. How to map tests in vsif to vPlan items
  • Subscribers 66
  • Views 14998
designer
designer over 8 years ago
 Hi All,
anybody has experience with mapping tests to vPlan in vsif file?
I am using the vManager Client (15.20.s010)! In the vsif file I use the attribute vplan_ref to map a test to a TC item in the vPlan. It looks like below:
       test my_test {make_args: "cpu=ON"; sv_seed: random; count: 4; vplan_ref: DOORS_A.SysTS.A_TS_Vplan_Export/A.SysTS-105/A.SysTS-106/A.SysTS-633/A.SysTS-107;};
When the  regression is finished, I load the vPlan in GUI (Analysis part)! But the test is not mapped? the configuration file for coverage has below commands:
select_coverage -all
set_com -log set_com.log
select_functional -imm_asrt_class_package
and in the session log file I see the below attribute is set by vManager
      BRUN_VPLAN_REF="DOORS_A.A_TS_Vplan_Export/A.SysTS-105/A.SysTS-106/A.SysTS-633/A.SysTS-107"; export BRUN_VPLAN_REF
Appreciate your comments!
