  2. Functional Verification
  3. ncsim: *E,CLNAIA: Cannot call system tasks/functions while...
  • Subscribers 67
  • Views 3710
ncsim: *E,CLNAIA: Cannot call system tasks/functions while analog engine is interactive
albas
albas over 9 years ago
here is my simulation log excerpt:
ncsim> uvm_config_db -trace on
ncsim: *E,CLNAIA: Cannot call system tasks/functions while analog engine is interactive.
while executing
"call tcl_uvm_config_db 1 [cdns_get_on_off_mapping $v5] "
("-trace" arm line 1)
invoked from within
"switch -regexp -- $args {
"-dump\\s+-audit" { call tcl_uvm_config_db 0 1 }
"-dump" { call tcl_uvm_config_db 0 0 }
"-trace" { cal..."
(procedure "uvm_config_db" line 10)
invoked from within
"uvm_config_db -trace on "
ncsim>
What actually does it mean? I'm using the ultrasim solver.
  • StephenH
    StephenH over 9 years ago
    If you look at the expanded help message, you'll see that the simulator appears to be stopped in a call to the analog model; you need to bring it back into the digital domain before you can issue this particular Tcl call.
    bash-4.1$ nchelp ncsim CLNAIA
    ncsim/CLNAIA =
    Calling system tasks/functions or C-language user defined functions
    is not supported while the analog engine is interactive. Use the
    run -sync command to advance the simulator to where the digital engine
    is active before issuing the call command.
  • albas
    Hi Steve,
    Thank you for your feedback, I must admit though that I haven't understood your proposal. My objective is to run the simulation in batch mode, I needed the gui for some debugging though.
  • StephenH
    Whether in GUI mode or batch execution, try issuing the command "run -sync" before the "uvm_config_db -trace on" command (regardless of whether you're issuing the uvm_config_db command at the Tcl prompt, via a script, or clicking the corresponding GUI button.
  • albas
    Thank you very much! It worked as expected.
    Al
