  2. Functional Verification
  3. Compilation Errors for UVM constructs using xcelium
  • Subscribers 67
  • Views 17266
Iovi
Iovi over 9 years ago
I will shortyly tell the problem:
The following code line :
if(!$cast(tmp,rhs))
`uvm_fatal(get_type_name().toupper(), "Type mismatch")
Generates two different errors at compile time :
*E,FCBLTIN ... built-in method call following a function call is not generally supported.
*E,NOTFXX ... Expecting a function name [10.3.3(IEEE)].
I cannot find out why this is not working.
Thanks in advance for the help,
Luca
