  2. Functional Verification
  3. False GLS timing violation being reported from irun for...
  • Subscribers 67
  • Views 15654
False GLS timing violation being reported from irun for Functional D input in Scan mode
bhanu27
bhanu27 over 9 years ago
Hi
I am running GLS sims for atpg vector,
I am getting violation for D input even when ATPG Select (SEL) signal is high and it is TD (test Data) input which matters.
Following is the task $setuphold  in my Flop model
 $setuphold(posedge CK &&& RB, negedge D &&& ~SEL, 4.49:4.49:4.49, -1.39:-1.39:-1.39, flag,,,d_CK, d_D);
In SDF file the timing check for this flop is
(SETUPHOLD (negedge D) (posedge CK) (x:y:z) (a:b:c))
Now if SEL is high violation from D input should not be taken into consideration and be masked as per $setuphold task above.
But while scan is happening and D input changes I get timing violations for D input setup time of Flop.
Please let  me know if you have faced similar issue and what was your solution
  • bhanu27
    My problem is resolved and it was a tool issue. I was using irun version 15.20-s004. When I changed my tool version the issue was gone.
