  2. Functional Verification
  3. How do I port a signal (reference data) from testbench to...
  • Subscribers 67
  • Views 16070
How do I port a signal (reference data) from testbench to RTL module?
Ncsim User 1
Ncsim User 1 over 8 years ago
I run some encryption logic and wish to mirror some reference data from testbench to RTL module,
exactly the opposite compared to what one would normally do to mirror existing singals from RTL to TB.
The signal doesn't exist in RTL, I want to use TB to generate a singal in RTL and mirror values to it.
Can that be done in ncsim or irun?
  • StephenH
    StephenH over 8 years ago
    I don't really understand the intention here; if the signal doesn't already exist in the design, what's the point of creating a new signal with no connections inside the RTL?
    If you really want to do this, perhaps the easiest way is to use a PSL vunit declaration, which in effect adds code in-line to the target module. Assuming that the module you want to add the signal to is called "target_mod", and the signal you want to create is "tb_data" (replace with your own names)... Create a file called target_mod.psl with the following content:
    vunit (target_mod) {
      logic [31:0] tb_data;
    Now, pass this to the compile + elab irun command using the option "-propfile_vlog target_mod.psl".
    You can then use a traditional Verilog OOMR (out of module reference) or $nc_mirror() to reflect the TB signal into the RTL.
  • Ncsim User 1
    Ncsim User 1 over 8 years ago in reply to StephenH
    Thank you that seems working.
