  2. Functional Verification
  3. Possible to mix ncsim(64b) with DPI-C/C compiled in 32-bit...
  • Subscribers 67
  • Views 1373
Possible to mix ncsim(64b) with DPI-C/C compiled in 32-bit address space?
Ncsim User 1
Ncsim User 1 over 8 years ago
I use ncsim 64 bit version 15.10, with DPI-C to run a large C application. The C does large amount of signal processing and mainly work in 32-bit environment.
The ncsim uses 64 bit and I can't change that.
The C application contains many *(uint32_t *)((uint32_t) ) which I am very reluctant to change into uint64_t.
Are there any switch so while I use 64-bit while C application runs in a 32 bit address space?
  • Ncsim User 1
    I figured I could hack by pointing uint32_t to a uint64_t and it worked.
