  2. Functional Verification
  3. How to collapse and expand the group in simvision with tcl...
  • Subscribers 66
  • Views 4375
How to collapse and expand the group in simvision with tcl command?
Jeff000
Jeff000 over 8 years ago
As far as I know, we can run
group insert
to insert signals as a group, but the group  would be expanded by default.
then how to insert the group as collapsed group with tcl command?
Thanks.
  • Doug Koslow
    Doug Koslow over 8 years ago +1
    Hi, You can use the "waveform hierarchy collapse <id>" command to collapse a group, where <id> is the waveform trace id returned from the "waveform add -groups" command. For an example of how the commands…
  • Doug Koslow
    For an example of how the commands should look, simply create a group in the waveform, collapse it, then save the waveform to a command file using the "Save signals" toolbar button. This file will show the required commands.
    Thanks.
    - Doug
  • Jeff000
    Jeff000 over 8 years ago in reply to Doug Koslow
    Thank you Doug.
    It works now!
