  2. Functional Verification
  3. Capturing glitches in Xcelium
  • Subscribers 67
  • Views 20049
kooltoad
kooltoad over 8 years ago
So I am seeing this weird behavior in my simulation where a register captures a value but nothing in the input logic cone has changed.
For e.g.,
a <= (b & c) | (!d) | (~e &f)
where a is non zero at the rising edge of the clock but b,c,d,e,f are unchanged. I am suspecting that one of them has a glitch which gets captured by "a". Although I can't see any glitches in my waveform.
Is there an environment variable that will enabling capturing glitches?
Thanks and Regards,
  • tpylant
    tpylant over 8 years ago +1
    You can enable event recording using: xmsim> database -open waves.shm -event In the waveform window, you will see small yellow circles where multiple events occur within a single time slice. Use the…
  • tpylant
    In the waveform window, you will see small yellow circles where multiple events occur within a single time slice. Use the View menu to expand the time to see the individual events.
    Tim
