  2. Functional Verification
  3. Coverage not getting hit when trying with IUS simulator
  • Subscribers 67
  • Views 17049
anikam
anikam over 8 years ago
Hi
I am seeing discrepancy in cover bins getting hit , I have total 10 cover bins out of which valid 8 get hit with VCS , however with IUS none of my valid bin gets hit.
I have put display prints to see whether "values" are being received in monitor call back file or not, I see that prints are coming with correct values for both IUS and VCS , however the bin doesn't get hit, when seen with imc -gui tool.
Please can anyone help in this regard.
Regards
Anika
  • tpylant
    tpylant over 8 years ago
    Can you provide more details of your cover group? Sharing an example would be extremely helpful. Please show the cover group trigger and explain how the trigger signal is generated.
    Tim
  • anikam
    anikam over 8 years ago in reply to tpylant
    Thanks tim for your response.
    Let me give an example :
    class A extends def_cov_data_callback;
    covergroup transaction_type@(xact_sample);
        type_option.comment = "coverage";
        option.per_instance = 1;
        cmd : coverpoint xact.cmd iff((xact.set_ccc == 0) && (xact.data_type == `ABC))
          option.comment = "This coverpoint captures coverage of commands sent by Master";
          bins write_cmd     = {WRITE};
          bins read_cmd      = {READ};
        broadcast_header : coverpoint xact.broadcast_header
          bins with_brdcast_header     = {1};
          bins without_brdcast_header  = {0};
    and so on
    endgroup
    endclass
    This xact_sample is event which is declared in file "cov_data_callback.sv"
    class cov_data_callback extends callback;
    event xact_sample;
    function transaction_observed_cov()
    $display("PRINTING XACT")
    xact.print(); ----------------------------------- Till this point my displays come fine in the log with IUS , I see correct values but still bin doesn't hit.
    ->this.xact_sample
    endfunction
    endclass
    Let me know if you need any other information
    Regards
    Anika
  • tpylant
    tpylant over 8 years ago in reply to anikam
    Here is the complete code I generated based on your example:
    typedef enum bit {READ, WRITE} cmd_e;
    typedef enum bit {ABC, XYZ} data_e;
    class xact_c;
      rand cmd_e  cmd;
           bit    set_ccc;
      rand data_e data_type;
      constraint cmd_const {data_type dist {ABC := 1, XYZ := 1};}
      constraint type_const {data_type dist {ABC := 1, XYZ := 1};}
      function void print();
        $display("xact print %n, %b, %n", cmd, set_ccc, data_type);
      endfunction
    endclass
    class cov_data_callback;
      event xact_sample;
      xact_c xact = new();
      function void transaction_observed_cov();
        $display("PRINTING XACT");
        xact.print();
        //Till this point my displays come fine in the log with IUS
        //I see correct values but still bin doesn't hit.
        ->this.xact_sample;
      endfunction
    endclass
    class A extends cov_data_callback;
      covergroup transaction_type @(xact_sample);
        cmd : coverpoint xact.cmd iff((xact.set_ccc == 0) && (xact.data_type == ABC))
      endgroup
      function new();
        super.new();
        transaction_type = new();
      endfunction
    endclass
    module test;
      A grpTest = new();
      initial begin
        repeat (10) begin
          #1 void'(grpTest.xact.randomize());
          grpTest.transaction_observed_cov();
        end
      end
    endmodule
    The output is:
    PRINTING XACT
    xact print WRITE, 0, ABC
    PRINTING XACT
    xact print WRITE, 0, XYZ
    PRINTING XACT
    PRINTING XACT
    PRINTING XACT
    PRINTING XACT
    PRINTING XACT
    xact print READ, 0, ABC
    PRINTING XACT
    PRINTING XACT
    PRINTING XACT
    And the coverage is:
    So with my example, the coverage report is lining up with the displayed output.
    Tim
