  2. Functional Verification
  3. Multi Dimensional Dynamic Array Constraint support Issue...
  • Subscribers 67
  • Views 5603
Multi Dimensional Dynamic Array Constraint support Issue in System Verilog/UVM
mahee424
mahee424 over 8 years ago
I've  the below example for multi dimensional dynamic array randomization;
    Class base extends uvm_sequence_item;
        rand integer array_of_frames[][][];
        rand int   frame_height;
        rand int frame_width;
        rand int no_of_frames;
        constraint no_of_frames_c { no_of_frames>1;no_of_frames<3;}
        constraint frame_height_c { frame_height>10;frame_height<20;}
        constraint frame_width_c {frame_width>1;frame_width<100;}
       function void  post_randomize();
           for(int i=0; i<array_of_frames.size; i++) begin
             for(int j=0; j<array_of_frames[i].size; j++) begin
                for(int k=0; k<array_of_frames[i][j].size; k++) begin
                        $write("0x%x ", (array_of_frames[i][j][k] & 32'hFF));
                end
                $display(" ");
             end
            $display(" ");
           end
       endfunction
    endclass
   After calling the randomization on above item,IRUN throws the below error.
  Warning: The generated size 130953965 of the queue/dynamic array is extremely large in IRUN and also causing the randomization failure.
   I've tried with the other tools and no issues found.
Please help and suggest a possible solution in NCSIM to allocate memory for above multi dimensional dynamic array?
Mahesh.
  • StephenH
    StephenH over 8 years ago
    Hello Mahesh.
    Dynamic arrays do not get allocated by randomisation, so based on the small snippet of code you've shared, the array_of_frames will still be empty after the randomize() call.
    I assume you are allocating the array before calling randomize(). What are the dimensions that you've set?
    You also appear to have missed some constraints on the size of array_of_frames, there is nothing linking that to the other rand variables in your constraints.
    If you can share a runnable example that show the error, it'll be a lot easier to help you. You should also state which simulator version you're using.
  • mahee424
    mahee424 over 8 years ago in reply to StephenH
    Hi Stephen,
         I've missed some logic in the previous post. Below is the complete example in system verilog;
    program main();
        class base;
           rand int array_of_frames[][][];
           constraint array_of_frames_c {
                 array_of_frames.size == no_of_frames;
                 foreach (array_of_frames[i]) {           array_of_frames[i].size == frame_height;          }
                foreach (array_of_frames[i,j]) {            array_of_frames[i][j].size == frame_width;      }
            end
           $display(" ");
         end
       $display(" ");
     end
    endfunction
    endclass
    base b0 = new();
    initial
    void'(b0.randomize());
     endprogram
    After simulation I've been observed the below message from irun.log;
    ncsim: *W,SVRNDF (./multi_ddynamic_array.sv,53|19): The randomize method call failed.
    Observed simulation time : 0 FS + 1
    ncsim: *W,RNDOCS: These constraints contribute to the set of conflicting constraints:
    constraint frame_height_c { frame_height>10;frame_height<20;} (./multi_ddynamic_array.sv,19)
    foreach (array_of_frames[i]) { (./multi_ddynamic_array.sv,25)
    ncsim: *W,RNDOCS: These variables contribute to the set of conflicting constraints:
    rand variables:
    frame_height [./multi_ddynamic_array.sv, 11]
    I'm using the below NCSIM Version;
       /tools/icad/cadence_lnx/ius/141.014/tools/bin/irun
    Please help in this regard whether I've missed something on constraints. However the above code is working fine with the other tools.
    Mahesh.
  • mahee424
    mahee424 over 8 years ago in reply to mahee424
       Does anyone tell me that the above issue will get resolved by using the latest IUS  version 15.20?
