  2. Functional Verification
  3. run_phase doesn't update SV interface signals
  • Subscribers 67
  • Views 3826
Sporadic Crash
Sporadic Crash over 8 years ago
I am trying to set up a minimal UVM env to learn this methodology.
My problem is that UVM driver doesn't seem to update the interface signals connected to DUT. Testbench can update it (clock and reset are driven). Counter runs because clock and reset could be applied.However the driver does not seem to work, even the $display in run_phase is not called. I have doubt that driver is setup properly. I have neither compilation nor elab errors.
Can anybody point me where my error is?
The example below is a derivative of the UVM example in Youtube film First Steps with UVM Part 2 by Doulos.
Shall I use modports in the interface?
Interface:
interface dut_if;
logic i_clk;
logic i_rst;
logic i_load_en;
logic [7:0] i_load_val;
logic [7:0] o_counter;
endinterface
DUT:
module my_counter (dut_if dif);
always_ff @(posedge dif.i_clk) begin
if (dif.i_rst)
dif.o_counter <= '0;
else if (dif.i_load_en)
dif.o_counter <= dif.i_load_val;
else
dif.o_counter <= dif.o_counter + 1;
end
endmodule
Testbench:
module tb ();
import uvm_pkg::*;
import my_pkg::*;
dut_if dif();
initial
begin
dif.i_clk = '0;
forever #10 dif.i_clk = ~dif.i_clk;
end
initial
begin
dit.i_rst = '1;
#15 dif.i_rst = '0;
end
my_counter dut (.dif (dif));
initial begin
`uvm_info ("SIM START", "Simulation has started!!", UVM_MEDIUM);
uvm_config_db #(virtual dut_if)::set(null, "*", "dut_if", dif);
uvm_top.finish_on_completion = 1;
run_test("my_test");
end
always @(posedge dif.i_clk)
begin
`uvm_info ("", $sformatf("DUT received %b", dif.o_counter), UVM_MEDIUM);
end
endmodule
UVM package:
package my_pkg;
import uvm_pkg::*;
class my_env extends uvm_env;
`uvm_component_utils (my_env)
function new (string name, uvm_component parent);
super.new(name, parent);
endfunction
endclass
class my_test extends uvm_test;
`uvm_component_utils (my_test)
my_env m_env;
super.new (name, parent);
endfunction
function void build_phase(uvm_phase phase);
m_env = my_env::type_id::create("m_env", this);
endfunction
task run_phase(uvm_phase phase);
phase.raise_objection(this);
#200;
`uvm_info("", "Hello world", UVM_MEDIUM);
phase.drop_objection(this);
endtask
endclass: my_test
class my_driver extends uvm_driver;
`uvm_component_utils (my_driver)
virtual dut_if dut_vi;
function new(string name, uvm_component parent);
endfunction
if (! uvm_config_db #(virtual dut_if)::get(this, "", "dut_if", dut_vi))
`uvm_error ("", "uvm_config_db::get failed");
endfunction
forever
begin
@(posedge dut_vi.i_clk);
$display ("run_phase!!");
dut_vi.i_load_en <= '0;
dut_vi.i_load_val <= $urandom;
end
endtask
endclass: my_driver
endpackage
Cadence version is 15.22.
  • TAM1
    TAM1 over 8 years ago +1
    The problem is that you have defined the driver class, but you haven't instantiated it inside of anything. I suspect you'll want to instantiate it inside your env class. Here is some code from a small…
  • TAM1
    The problem is that you have defined the driver class, but you haven't instantiated it inside of anything. I suspect you'll want to instantiate it inside your env class. Here is some code from a small testcase:
    class uvc_agent extends uvm_agent;
        uvc_driver driver;
        `uvm_component_utils_begin(uvc_agent)
             `uvm_field_object(driver,UVM_DEFAULT)
        `uvm_component_utils_end
        function new(string name = "uvc_agent", uvm_component parent = null);
         endfunction : new
         virtual function void build_phase(uvm_phase phase);
           super.build_phase(phase);
           driver = uvc_driver::type_id::create("driver", this);
        end
        endfunction : build_phase
    There is a lot more to do to build a real UVC. You may want to invest in a book like "A Practical Guide to Adopting the Universal Verification Methodology", a book which I reference often.
  • Sporadic Crash
    Sporadic Crash over 8 years ago in reply to TAM1
    Thanks to point this out. It was in the examples of Doulos not very clear.
    The driver works when instantiated in env or test class. I know this is the not the best.
    I will take a look at UVC agents from now on.for better and proper UVM test structure.
