  2. Functional Verification
  3. Specman - init a param value of internal sequence (execute...
  • Subscribers 67
  • Views 1222
Specman - init a param value of internal sequence (execute from another sequence) directly from test
sara8
sara8 over 8 years ago
I have a sequence (e.g SANITY_TEST seq) which execute another sequence (e.g BOOT seq). The BOOT seq contains the following param:
index_v : uint(bits:4) ;
I have the following test :
extend MAIN ocp_master_sequence_q {
    body()@driver.clock is only {
      do SANITY_TEST seq ;
Is there any way to execute SANITY_TEST seq from the test and init the index_v param of the BOOT_seq directly from the test?
