  2. Functional Verification
  3. Constraints for multidimensional array
  • Subscribers 67
  • Views 18110
Egor
Egor over 8 years ago
Hello guys. Have no idea why my code doesn't work in IUS 15.2/051 simulator. I tried to generate two-dimensional array with random size , but randomization method was failed ?! Can you make a comment  ? Or suggest how to fix it ?
class test;
  rand int array[][];
  rand int first_size;
  rand int second_size;
  function new();
  endfunction // new
  constraint array_cnstr{
    array.size() == first_size;
    foreach(array[i])
    array[i].size == second_size;
  constraint array_size_cnstr{
    first_size inside {[10:15]};
    second_size inside {[10:15]};
  function void show_array();
    $display("first_size %0d" , first_size);
    $display("second_size %0d" , second_size);
    foreach(array[i,j])
      $display("array[%0d,%0d] = %0d" , i , j , array[i][j]);
    endfunction // show_array
  endclass // test
module test_mod();
  test ObjTest;
  initial begin
    ObjTest = new();
    ObjTest.randomize();
    ObjTest.show_array();
  end
endmodule
Error, that I got :
ncsim> source /cad/cadence/INCISIV152.051/tools/inca/files/ncsimrc
ncsim> run
ncsim: *W,SVRNDF (./test.sv,38|22): The randomize method call failed. The unique id of the failed randomize call is 0.
Observed simulation time : 0 FS + 0
ncsim: *W,RNDOCS: These constraints contribute to the set of conflicting constraints:
foreach(array[i]) (./test.sv,14)
second_size inside {[10:15]}; (./test.sv,20)
ncsim: *W,RNDOCS: These variables contribute to the set of conflicting constraints:
rand variables:
second_size [./test.sv, 7]
  • StephenH
    StephenH over 8 years ago
    Hello Egor.
    This looks very much like the same question someone else had a few weeks ago on this forum. Is it a class homework assignment by any chance?
    Generating random data this way isn't very efficient for the tool as you're invoking a heavy complex solver to just assign simple random values (for the array contents) that you could get from $urandom().
  • Egor
    Egor over 8 years ago in reply to StephenH
    Hello StephenH , thank you for your response.
    I've just shown you this code as example. Actually I used the same method in uvm sequence randomization . What I want is to have a hook to control dynamic array size from the upper layer that creates this  sequences with dynamic array using randomize with construct. I'm pretty sure that this construction is supported with SV . I tried this code on edaplayground with other vendor simulator and it works.
