  2. Functional Verification
  3. xrun timing check
  • Subscribers 67
  • Views 6293
xrun timing check
FormerMember
FormerMember over 8 years ago
I have to perform an RTL simulation using some library cells and some models. Both files have the timing information through specify/specparam definition.
I would like to suppress timing information for the library cells but I want to keep the timing information relative to my models; so I cannot use the -nospecify option during simulation, otherwise all the timing information will be cleaned.
Is it possible to remove the timing information from only some blocks?
I've also tried to precompile the library using -makelib -nospecify options but it doesn't work.
Thanks!
  • cmarqu42
    cmarqu42 over 8 years ago
    I think that is a case for the -tfile option.
