  2. Functional Verification
  3. What is the recommended usage : vaelab vs hdlSynthesize...
  • Subscribers 68
  • Views 18203
What is the recommended usage : vaelab vs hdlSynthesize?
Rama Kishore
Rama Kishore over 8 years ago
I  am going through palladium uxe userguide, which gives user two option to do an rtl/hdl import in ICE mode. User can use either
1) vavlog+vaelab  utilities
or
2) hdlImport+hdlSynthesize xel commands to xeCompile
Is there a recommendation to use one over the other? What is the better approach? Why do we have two approaches - what is the latest?
Regards
Ram
  • Seven Xu
    Seven Xu over 5 years ago
    vavlog+vaelab should provided more options than hdlImport+hdlSynthesize.
    vavlog+vaelab can used as command line interface and can integrated with linux scripts.
    hdlImport+hdlSynthesize.is more often used as tcl command in xeCompile.
    So I think for most time vavlog+vaelab is more recommended,
  • Rama Kishore
    Rama Kishore over 5 years ago in reply to Seven Xu
    Thank you Seven..
