  2. Functional Verification
  3. SDF back annotation in systemVerilog design using inter...
  • Subscribers 67
  • Views 16042
SDF back annotation in systemVerilog design using interfaces
arash1902
arash1902 over 8 years ago
I have a DUT which is encrypted netlist and .sdf file (normally we do functional and timing simulations with these inputs). I used interface feature in SystemVerilog so I don't define any port for the modules. here is part of the code:
module topmodule(
intf1   clk,inp1,inp2,outp);
intf1  out();
// Instance the interface with an input, using named connection
 RC DUT(clk, inp1, inp2, out);
and here is part of interface definition,
interface intf1;
logic data=0;
and I have two task and function in my interface. I write a SDF file but modelsim said 'failed to find port '/tbench_top/clk/data' and 'failed to find port '/tbench_top/DUT/inp1/data'. It means it didn't recognize the 'data' port which is defined within the interface. here is part of my SDF file,
INTERCONNECT clk.data DUT.inp1.data (.145::.145) (.125::.125))
So, how must I write SDF when I use interfaces? Thanks for any help.
