  2. Functional Verification
  3. Fork a task with parameter from within a function
  • Subscribers 66
  • Views 2281
Jeff000
Jeff000 over 8 years ago
Below is what I've tried to start a task with parameter from a function.
function fork_task_in_func()
	for (int i = O; i < 3; i++) begin
		fork
		  print_me(i);
		join_none
	end
endfunction
task print_me(int i);
	$display("print me: i: %Od\n", i);
endtask
What I expect is as follows,
print me: i: 0
print me: i: 1
print me: i: 2
But the actual outputs are,
print me: i: 3
print me: i: 3
print me: i: 3
Anyone can explain a bit for this result?
Thanks.
  • StephenH
    StephenH over 8 years ago in reply to Jeff000 +1
    My apologies, I replied before my morning coffee and got the automatic variable in the wrong place, I've updated my post to show the correct code. See also the end of section 9.3.2 in the 2012 LRM.
  • StephenH
    The forked threads are not started until the join_none is reached, meaning that when the threads start the for loop has finished and i == 3. The LRM explains this in some detail, and shows the correct way to do it using an automatic variable. This automatic variable works because the initialiser takes effect instantly rather than waiting till the thread starts.
    for (int i=0; i<3; i++) begin : loop
    fork
    automatic int ii = i;
    begin
    print_me(ii);
    end
    join_none
    end : loop
  • Jeff000
    Jeff000 over 8 years ago in reply to StephenH
    Thanks.
    If the forked threads won't get started until the end of the for loop, then the automatic ii will still be assigned with the i == 3, right?
    I've tried as your suggestion but still have the following output,
    print me: i: 3
    print me: i: 3
    print me: i: 3
  • StephenH
