  2. Functional Verification
  3. How to show posedges by Simvision expression?
  • Subscribers 66
  • Views 3989
Jeff000
Jeff000 over 8 years ago
In Simvision, users can easily view conditional combination of some signals by its expression feature.
However, if I want to view conditions like,
@posedge(A) & (B == 'h1234)
How can I achieve this by Simvision expression?
Thanks.
  • Doug Koslow
    Doug Koslow over 8 years ago +1
    Hi, Although the SimVision Expression Calculator does not support a "posedge" operation directly, you can use the "shift" operation (that receives time shifted value of a signal) to simulate it. Consider…
  • Doug Koslow
    Consider the following example:
    (A === 1'b1 && shift(A, <period>) === 1'b0 && B === 'h1234) ? 1'b1 : 1'b0
    Replace the signal names above with the full path names from the design, and <period> above with half the period. (Assuming A is periodic.)
    Please give this a try.
    Thanks.
    - Doug
  • Jeff000
    Jeff000 over 8 years ago in reply to Doug Koslow
    That indeed works for me. Thank you!
