  2. Functional Verification
  3. DLCSMD Errors
  • Replies 8
  • Subscribers 69
  • Views 32346
DLCSMD Errors
Chris Hopkins
Chris Hopkins over 8 years ago
I'm getting the following compile error:
xmvlog: *E,DLCSMD: Dependent checksum verilog_package work.foo_pkg:sv (VST) doesn't match with the checksum that's in the header of: verilog_package work.foo_bar_pkg:sv (VST).
import foo_bar_pkg::*;
This is starting from a completely clean build. (Historic posts on this error have talked about removing INCA_libs as the solution).
Other than that I can't see what we could be doing here to cause this error. Any suggestions would be greatly received.
Kind Regards
  • TAM1
    TAM1 over 8 years ago in reply to Chris Hopkins +2
    I believe you can also see these errors if the source code is compiled multiple times. For example, by using `include "mypackage.sv" in multiple places. Perhaps enclosing `include directives with `ifdefs…
  • cmarqu42
    cmarqu42 over 8 years ago in reply to cmarqu42 +1
    As some kind of last resort, "strace -f -o strace.log xrun ..." may also give you an idea what is being done to your files. (strace also has some powerful options for filtering.)
  • cmarqu42
    The INCA_libs directory is called xcelium.d these days, but try the -clean and -cleanlib options first.
  • Chris Hopkins
    Chris Hopkins over 8 years ago in reply to cmarqu42
    Indeed, clean as noted makes no difference.
  • cmarqu42
    cmarqu42 over 8 years ago in reply to Chris Hopkins
    "xmhelp xmvlog DLCSMD" also suggests some causes, like two design units with the same name but different content or two compilations of the same file with different options - could this apply?
  • Chris Hopkins
    That is a really good point. I'm trying to pick through exactly what is happening with our packages as there are multiple RECOME warnings with this build. Many of those warnings referencing package foo as the package that is the cause of their recompilation. All the ones I've checked are seeming to be recompiled as package x is referenced in multiple other packages and so it is rebuilt for each of these candidate packages (not because of configuration differences).
    I don't have any evidence at the moment that there is any repetition of content, but we certainly have different parameters used with this module. I *hope* that isn't a problem though.
    To be clear, the two compilations would be coming not from the different parameters, but from any changes with build options and defines. At least that's my understanding of why a recompilation would be needed.
  • cmarqu42
  • TAM1
    I believe you can also see these errors if the source code is compiled multiple times. For example, by using `include "mypackage.sv" in multiple places. Perhaps enclosing `include directives with `ifdefs would help.
    `ifndef MYPACKAGE
      `define MYPACKAGE
    `endif
    Search your source code for every `include directive and see if there are duplicates.
    • Vote Up +2 Vote Down
  • Chris Hopkins
    Chris Hopkins over 8 years ago in reply to TAM1
    Just discovered that this is indeed happening.
    Unfortunately this is 3rd party ip (hence me being so vague about some of the details so names redacted to protect...) so I can't actually edit the source.
    Thanks I now know what is wrong, how to fix it without being able to change the code is another issue entirely!
    Much appreciated.
  • cmarqu42
    cmarqu42 over 8 years ago in reply to TAM1
    Good suggestion, though you'd normally protect the content of "mypackage.sv" that way, not every place where it's included (see e.g. https://en.wikipedia.org/wiki/Include_guard).
