  2. Functional Verification
  3. What could be the reason of *E,DLCSMD error?
  • Subscribers 67
  • Views 6725
Jeff000
Jeff000 over 8 years ago
I ran into an error like,
*E,DLCSMD Dependent checksum module A.B:module (VST) doesn't match with the checksum that's in the header of: snapshot worklib.top_dut:sv (SSS).
*F, NOSIMU: Errors initializating simulation 'top_dut'.
Any one can suggest on this?
Thanks.
  • Tudor Timi
    Tudor Timi over 8 years ago
    I remember getting this error for multi-step compiles (i.e. multiple 'irun' calls), where you compile a design object in one compile and then re-compile it in a subsequent compile. In your case, I'd suspect you compile 'top_dut', 'A' and 'B' in one compile and then somehow recompile 'B'.
