  2. Functional Verification
  3. What's the definition and the function of value()
  • Subscribers 67
  • Views 2338
TaoZ
TaoZ over 8 years ago
Hi, all
I'm new to specman E, and begin learning it by reading Design Verification with E. I've many times the utilization of function value, such as:
keep tx_monitor.file_logger.to_file == value(tx_log_filename);
keep tx_bfm.driver == value(tx_driver);
Could anyone explain me about the utilization of value().
Many thanks!
Tao
  • hannes
    hannes over 8 years ago
    When 2 variables are linked by a constraint, they are in a bidirectional relationship. E.g keep a>b links a and b, so b needs to be bigger than a and a smaller than b.
    Sometimes you don't want a bidirectional relationship, e.g. keep a = crc_function(data). So here a and data are in a unit-directional relationship. Data needs to be generated
    before a, and then the function is called and the result assigned to a.
    value() is just a function call returning the value. But for the generator, it also create a unidirectional relationship. To assign pointers in a testbench, the use of value() (or read_only()) is recommended. Generally testbench containers (units) are created in a specific order, and there are no bidirectional relationships. And to assign a pointer to something that already exists, just use value() or read_only()
  • TaoZ
    TaoZ over 8 years ago in reply to hannes
    Hi, Hannes
    Thanks for your reply, which make me have a better understanding of value().
    Nice Weekends!
    Tao
