  2. Functional Verification
  3. How do I control probe start/stop in ncsim from embedded...
  • Subscribers 67
  • Views 9463
How do I control probe start/stop in ncsim from embedded CPU?
Ncsim User 1
Ncsim User 1 over 8 years ago
I am running an RTL simulation with an embeddd CPU and some encryption logic.
The CPU runs some codes to check the result of encryption logic and can run hours or days.
My idea is to let the CPU control when to dump waveforms, likely when some conditions are met in the logic. Then stop when the conditon elapses.
How should I do that?
  • StephenH
    StephenH over 7 years ago +1
    The simplest way would be to use Tcl breakpoints to execute the probe commands when certain signal values are observed. For example, at the start of simulation, create the probe for the signals you want…
  • StephenH
    The simplest way would be to use Tcl breakpoints to execute the probe commands when certain signal values are observed. For example, at the start of simulation, create the probe for the signals you want to debug, and give the probe a name, then immediately disable it (unless you want to probe at time 0):
    probe -create -shm -name myprobe <list_of_signals>
    probe -disable myprobe
    Then, create breakpoints to turn the probe on and off:
    stop -create -execute {probe -enable myprobe} -continue -condition {[value top.sig_to_start_probing] = 1'b1}
    stop -create -execute {probe -disable myprobe} -continue -condition {[value top.sig_to_start_probing] = 1'b0}
    There are many other types of breakpoints so you'll need to use your imagination to decide which is the most appropriate for your scenario.
    I would also suggest thinking about whether it's better to check the encryption result using some zero-time method in the testbench instead of having a simulated CPU to crunch the data, your tests would finish much quicker and be much easier to debug!
  • Ncsim User 1
    Ncsim User 1 over 7 years ago in reply to StephenH
    Thank you.
  • MayurAna
    MayurAna over 7 years ago in reply to StephenH
    Hello Stephen,
    I have provided the following sequence of commands in my tcl
    probe -create INST_CHANNEL -depth all -shm -database waves -name dumps
    probe -disable dumps
    stop -create -execute {probe -enable dumps} -continue -condition {[value tb_top.START_DUMP] = 1'b1}
    stop -create -execute {probe -disable dumps} -continue -condition {[value tb_top.START_DUMP] = 1'b0}
    When the above tcl script is not provided ( and without any dump or with a full dump ) the simulation completes in a few ms.
    When the above tcl script is provided the sim halts at "Created stop 2" and does not proceed.
    The default state of START_DUMP is 0 and toggles 1 to 0 and again 1 to 0 inbetween the sims.
    I would want the Scope INST_CHANNEL to be dumped only when START_DUMP is 1
    Would the above seq of commands really work ..
  • MayurAna
    MayurAna over 7 years ago in reply to MayurAna
    Thanks Stephen,
    I got it working .. I missed the "run"
