  2. Functional Verification
  3. How do I pass a string from irun to my DPI-C codes?
  • Subscribers 67
  • Views 16319
Ncsim User 1
Ncsim User 1 over 8 years ago
I use DPI-C to compile a C code and run with irun.
Assume I wish to pass a testcase directory to my C and Verilog codes. I managed to do it for Verilog but not my C code.
#!/bin/ksh
#TC=$2
TC=TEST_1
irun -64bit -access +rwC -g \
-gui \
other flags \
-DMYTC="TEST_1" \
other flags
IN my C code I would use
sprintf(str_filename, "%s/my_testcase.txt", MYTC);
  • StephenH
    StephenH over 8 years ago +1
    You can use "irun -defineall MYTC=TEST_1" to pass the same define to all language compilers. Alternatively you can pass strings from SV to C on the DPI call...
  • StephenH
  • Ncsim User 1
    Ncsim User 1 over 8 years ago in reply to StephenH
    Thank you for the reply StephenH.
